When establishing color schemes for components, it's essential to leverage Fuselage's palette system. This system provides a straightforward and meaningful approach to integrating colors through tokens. Tokens function similarly to Fuselage components, allowing updates to be made solely within the component, rather than requiring changes across the entire Rocket.Chat implementation. Additionally, the palette system facilitates the creation of diverse themes, as each theme can possess its palette implementation. For instance, a dark theme can share the same token groups while differing in token values, enabling versatile and consistent theming.
How to use the palette system
On box component
<Box bg='status-background-info' color='status-font-on-info' />To enhance simplicity and mitigate the risk of token misuse, a convenient shortcut exists that automatically applies the appropriate prefixes. When using surface tokens with the bg prop and font tokens with the color prop, you have the option to exclude the surface- and font- prefixes.
<Box bg='neutral' color='default' />Alternatively, you can use the longer form:
<Box bg='surface-neutral' color='font-default' />In Rocket.Chat and/or Fuselage - React components
Similar to other components, you can import the Palette from the Fuselage package using:
import { Palette } from '@rocket.chat/fuselage';Accessing tokens from the Palette becomes straightforward. For instance:
const SurfaceHoverColor = Palette.surface['surface-hover'];
const StrokeColor = Palette.stroke['stroke-extra-light'];By using the Palette system, any color modifications within Fuselage are automatically managed. This system also seamlessly adapts to changes introduced by the active theme, providing a streamlined and automated approach to color management.
On Fuselage .scss files
When working within a .scss file within the Fuselage package, you can seamlessly integrate tokens into your styles using the following approach:
@use '/packages/fuselage/src/styles/colors.scss'; // Use relative path
.example {
color: colors.font(titles-labels);
background-color: colors.surface(neutral);
border: 1px solid colors.stroke(extra-light);
}By incorporating the tokens provided by the colors.scss file, you can easily apply color styles to your components and ensure consistency with Fuselage's color palette.
