--- title: "Rocket Chat UIKit Block Elements" slug: "using-uikit-blocks" description: "Learn how to use UIKit block elements in Rocket Chat. Build secure, dynamic app interfaces for collaboration." updated: 2024-10-29T07:24:20Z published: 2024-10-29T07:24:20Z canonical: "developer.rocket.chat/using-uikit-blocks" --- > ## Documentation Index > Fetch the complete documentation index at: https://developer.rocket.chat/llms.txt > Use this file to discover all available pages before exploring further. # Using UIKit Blocks This document covers various examples to help you use the Apps-Engine UI blocks so you can create meaningful user interactions in your apps. The UI blocks are triggered by an action or a condition. In these examples, the UI blocks will be triggered when a message is starred. First, we will see how to create a single block and then we will add more elements to create complex visual layouts. ## Create a section block Let’s create a basic section that contains some text. This will be displayed in a room when a message is starred. The main app class looks like this: ```typescript import {    IAppAccessors, IConfigurationExtend, ILogger, IHttp, IModify, IPersistence, IRead, IMessageBuilder, IMessageRead } from '@rocket.chat/apps-engine/definition/accessors'; import { App } from '@rocket.chat/apps-engine/definition/App'; import { IAppInfo } from '@rocket.chat/apps-engine/definition/metadata'; import { UIKitInteractionType, IUIKitInteractionHandler, UIKitSurfaceType } from '@rocket.chat/apps-engine/definition/uikit'; import { OpenCtxBarCommand } from './contextbar'; import { uiKitMessage } from '@rocket.chat/ui-kit'; import { IMessage, IMessageStarContext, IPostMessageSent, IPostMessageStarred } from '@rocket.chat/apps-engine/definition/messages'; export class uiblocksApp extends App implements IPostMessageStarred {    async executePostMessageStarred(context: IMessageStarContext, read: IRead, http: IHttp, persistence: IPersistence, modify: IModify): Promise {        const messageCreator = modify.getCreator().startMessage();        messageCreator.setBlocks([            {                type: 'section', // the type of block                text: {                    type: 'plain_text',                    text: 'Message starred! :)',                    emoji: true                }            },        ])        messageCreator.setRoom(context.message.room);        await modify.getCreator().finish(messageCreator);    } } ``` Whenever a message is starred, the app bot returns the text message as shown in this screenshot: ![](https://cdn.us.document360.io/27ca1fd4-36d7-4cde-b4eb-97fc1652954c/Images/Documentation/image-1726214638390.png?sv=2026-02-06&spr=https&st=2026-11-11T01%3A03%3A08Z&se=2026-11-11T02%3A03%3A08Z&sr=c&sp=r&sig=BwCYCMsLdEU6SE2SNNmOV4uz%2BGwpcVv7DggHkuCPJM4%3D) ## Stack multiple blocks In the same example, we are going to add more blocks and elements to demonstrate how you can create complex UI layouts. ### Add an image block ```typescript async executePostMessageStarred(context: IMessageStarContext, read: IRead, http: IHttp, persistence: IPersistence, modify: IModify): Promise {        const messageCreator = modify.getCreator().startMessage();        messageCreator.setBlocks([            {                type: 'section', // section block                text: {                    type: 'plain_text',                    text: 'Message starred! :)',                    emoji: true                }            },            {                type: 'image', // image block                imageUrl: 'https://cdn0.iconfinder.com/data/icons/new-year-holidays-set/200/NewYearIcon7-01-1024.png',                altText: 'test image'            },        ])        //messageCreator.setText('Message starred! :)');        messageCreator.setRoom(context.message.room);        await modify.getCreator().finish(messageCreator);    } ``` ![](https://cdn.us.document360.io/27ca1fd4-36d7-4cde-b4eb-97fc1652954c/Images/Documentation/image-1726474291113.png?sv=2026-02-06&spr=https&st=2026-11-11T01%3A03%3A08Z&se=2026-11-11T02%3A03%3A08Z&sr=c&sp=r&sig=BwCYCMsLdEU6SE2SNNmOV4uz%2BGwpcVv7DggHkuCPJM4%3D) ### Add a divider block and an action block Now, instead of the image, we will add a divider and an action block. The action block contains a button element. ```typescript async executePostMessageStarred(context: IMessageStarContext, read: IRead, http: IHttp, persistence: IPersistence, modify: IModify): Promise {        const messageCreator = modify.getCreator().startMessage();        const appId = this.getID();        messageCreator.setBlocks([            {                type: 'section', // the section block                blockId: 'section_1',                text: {                    type: 'plain_text',                    text: 'Message starred! :)',                    emoji: true                }            },            {                type: 'divider', // the divider block                appId: appId,                blockId: 'divider_block_1'            },            {                type: 'actions', // the action block                appId: appId,                blockId: 'action_block_1',                elements: [ // the elements parameter contains the action element details, in this case, a button element                    {                        type: 'button',                        actionId: 'button_action_1',                        appId: appId,                        blockId: 'button_action_block_1',                        text: {                            type: 'plain_text',                            text: 'Learn more!'                        },                        style: 'primary',                        value: 'Button element'                    }                ]            },        ])        //messageCreator.setText('Message starred! :)');        messageCreator.setRoom(context.message.room);        await modify.getCreator().finish(messageCreator);    } ``` The following screenshot shows the UI: ![](https://cdn.us.document360.io/27ca1fd4-36d7-4cde-b4eb-97fc1652954c/Images/Documentation/image-1727335896178.png?sv=2026-02-06&spr=https&st=2026-11-11T01%3A03%3A08Z&se=2026-11-11T02%3A03%3A08Z&sr=c&sp=r&sig=BwCYCMsLdEU6SE2SNNmOV4uz%2BGwpcVv7DggHkuCPJM4%3D) ### Add an input block We will define an input block containing the static menu element type: ```typescript async executePostMessageStarred(context: IMessageStarContext, read: IRead, http: IHttp, persistence: IPersistence, modify: IModify): Promise {        const messageCreator = modify.getCreator().startMessage();        const appId = this.getID();        messageCreator.setBlocks([            {                type: 'section', // the section block                blockId: 'section_1',                text: {                    type: 'plain_text',                    text: 'Message starred! :)',                    emoji: true                }            },            {                type: 'divider', // the divider block                appId: appId,                blockId: 'divider_block_1'            },            {                type: 'actions', // the action block                appId: appId,                blockId: 'action_block_1',                elements: [ // the elements parameter contains the action element details, in this case, a button element                    {                        type: 'button',                        actionId: 'button_action_1',                        appId: appId,                        blockId: 'button_action_block_1',                        text: {                            type: 'plain_text',                            text: 'Learn more!'                        },                        style: 'primary',                        value: 'Button element'                    }                ]            },            {                type: 'input', // the input block                appId: appId,                blockId: 'input_block',                label: {                    type: 'plain_text',                    text: 'static_input'                },                element: { // the "element" object contains the definition of the type of input block you want to use, in this case, a static select menu                    type: 'static_select',                    actionId: 'static_select_action_1',                    appId: appId,                    blockId: 'static_select_block_1',                    placeholder: {                        type: 'plain_text',                        text: 'Select an option:',                    },                    options: [                        {                            value: 'option_1',                            text: {                                type: 'plain_text',                                text: 'This is your first option'                            }                        },                        {                            value: 'option_2',                            text: {                                type: 'plain_text',                                text: 'This is your second option'                            }                        }                    ]                }            }        ])        //messageCreator.setText('Message starred! :)');        messageCreator.setRoom(context.message.room);        await modify.getCreator().finish(messageCreator);    } ``` The following screenshot shows the blocks returned by the app bot: ![](https://cdn.us.document360.io/27ca1fd4-36d7-4cde-b4eb-97fc1652954c/Images/Documentation/image-1727336892072.png?sv=2026-02-06&spr=https&st=2026-11-11T01%3A03%3A08Z&se=2026-11-11T02%3A03%3A08Z&sr=c&sp=r&sig=BwCYCMsLdEU6SE2SNNmOV4uz%2BGwpcVv7DggHkuCPJM4%3D) ### Add a context block To the previous code snippet, we will add a context block definition as follows: ```typescript {                type: 'context', // the context block                appId: appId,                blockId: 'context_block',                elements: [                  {                    type: 'plain_text',                    text: 'This is a context block'                  }                ]              },        ])        //messageCreator.setText('Message starred! :)');        messageCreator.setRoom(context.message.room);        await modify.getCreator().finish(messageCreator);    } ``` The following screenshot shows what the context block looks like: ![](https://cdn.us.document360.io/27ca1fd4-36d7-4cde-b4eb-97fc1652954c/Images/Documentation/image-1727338318664.png?sv=2026-02-06&spr=https&st=2026-11-11T01%3A03%3A08Z&se=2026-11-11T02%3A03%3A08Z&sr=c&sp=r&sig=BwCYCMsLdEU6SE2SNNmOV4uz%2BGwpcVv7DggHkuCPJM4%3D) ### Add a preview block To this example, we will now add a preview block as follows: ```typescript {                type: 'preview', // the preview block                description: [                  {                    type: 'plain_text',                    text: 'Description of preview'                  }                ],                title: [                  {                    type: 'plain_text',                    text: 'Title of preview'                  }                ]              },                        ])        //messageCreator.setText('Message starred! :)');        messageCreator.setRoom(context.message.room);        await modify.getCreator().finish(messageCreator);    } ``` The following screenshot shows how the preview block appears in the UI: ![](https://cdn.us.document360.io/27ca1fd4-36d7-4cde-b4eb-97fc1652954c/Images/Documentation/image(106).png?sv=2026-02-06&spr=https&st=2026-11-11T01%3A03%3A08Z&se=2026-11-11T02%3A03%3A08Z&sr=c&sp=r&sig=BwCYCMsLdEU6SE2SNNmOV4uz%2BGwpcVv7DggHkuCPJM4%3D)
