This document covers various examples to help you use the Apps-Engine UI blocks so you can create meaningful user interactions in your apps. The UI blocks are triggered by an action or a condition. In these examples, the UI blocks will be triggered when a message is starred. First, we will see how to create a single block and then we will add more elements to create complex visual layouts.
Create a section block
Let’s create a basic section that contains some text. This will be displayed in a room when a message is starred. The main app class looks like this:
import {
IAppAccessors, IConfigurationExtend, ILogger, IHttp, IModify, IPersistence, IRead, IMessageBuilder, IMessageRead
} from '@rocket.chat/apps-engine/definition/accessors';
import { App } from '@rocket.chat/apps-engine/definition/App';
import { IAppInfo } from '@rocket.chat/apps-engine/definition/metadata';
import { UIKitInteractionType, IUIKitInteractionHandler, UIKitSurfaceType } from '@rocket.chat/apps-engine/definition/uikit';
import { OpenCtxBarCommand } from './contextbar';
import { uiKitMessage } from '@rocket.chat/ui-kit';
import { IMessage, IMessageStarContext, IPostMessageSent, IPostMessageStarred } from '@rocket.chat/apps-engine/definition/messages';
export class uiblocksApp extends App implements IPostMessageStarred {
async executePostMessageStarred(context: IMessageStarContext, read: IRead, http: IHttp, persistence: IPersistence, modify: IModify): Promise<void> {
const messageCreator = modify.getCreator().startMessage();
messageCreator.setBlocks([
type: 'section', // the type of block
text: {
type: 'plain_text',
text: 'Message starred! :)',
emoji: true
messageCreator.setRoom(context.message.room);
await modify.getCreator().finish(messageCreator);
}Whenever a message is starred, the app bot returns the text message as shown in this screenshot:
Stack multiple blocks
In the same example, we are going to add more blocks and elements to demonstrate how you can create complex UI layouts.
Add an image block
type: 'section', // section block
text: {
type: 'plain_text',
emoji: true
type: 'image', // image block
imageUrl: 'https://cdn0.iconfinder.com/data/icons/new-year-holidays-set/200/NewYearIcon7-01-1024.png',
altText: 'test image'
//messageCreator.setText('Message starred! :)');
Add a divider block and an action block
Now, instead of the image, we will add a divider and an action block. The action block contains a button element.
const appId = this.getID();
type: 'section', // the section block
blockId: 'section_1',
text: {
type: 'plain_text',
emoji: true
type: 'divider', // the divider block
appId: appId,
blockId: 'divider_block_1'
type: 'actions', // the action block
appId: appId,
blockId: 'action_block_1',
elements: [ // the elements parameter contains the action element details, in this case, a button element
type: 'button',
actionId: 'button_action_1',
appId: appId,
blockId: 'button_action_block_1',
text: {
type: 'plain_text',
text: 'Learn more!'
style: 'primary',
value: 'Button element'
}The following screenshot shows the UI:
Add an input block
We will define an input block containing the static menu element type:
text: {
type: 'plain_text',
emoji: true
appId: appId,
appId: appId,
type: 'button',
appId: appId,
text: {
type: 'plain_text',
text: 'Learn more!'
style: 'primary',
type: 'input', // the input block
appId: appId,
blockId: 'input_block',
label: {
type: 'plain_text',
text: 'static_input'
element: { // the "element" object contains the definition of the type of input block you want to use, in this case, a static select menu
type: 'static_select',
actionId: 'static_select_action_1',
appId: appId,
blockId: 'static_select_block_1',
placeholder: {
type: 'plain_text',
text: 'Select an option:',
options: [
value: 'option_1',
text: {
type: 'plain_text',
text: 'This is your first option'
value: 'option_2',
text: {
type: 'plain_text',
text: 'This is your second option'
}The following screenshot shows the blocks returned by the app bot:
Add a context block
To the previous code snippet, we will add a context block definition as follows:
type: 'context', // the context block
appId: appId,
blockId: 'context_block',
elements: [
type: 'plain_text',
text: 'This is a context block'
}The following screenshot shows what the context block looks like:
Add a preview block
To this example, we will now add a preview block as follows:
type: 'preview', // the preview block
description: [
type: 'plain_text',
text: 'Description of preview'
title: [
type: 'plain_text',
text: 'Title of preview'
}The following screenshot shows how the preview block appears in the UI:
.png?sv=2026-02-06&spr=https&st=2026-11-11T00%3A53%3A02Z&se=2026-11-11T01%3A13%3A02Z&sr=c&sp=r&sig=JiYRmNM8EAPzNRY04YnJeEjkOsSnDnytWzTB3Sh8EwQ%3D)
