--- title: "Contribute to Rocket Chat Apps-Engine" slug: "contribute-to-apps-engine" description: "Discover how to contribute to Rocket Chat Apps-Engine. Build secure extensions, share features, and support developer collaboration." updated: 2024-06-11T16:04:24Z published: 2024-06-11T16:04:24Z canonical: "developer.rocket.chat/contribute-to-apps-engine" --- > ## Documentation Index > Fetch the complete documentation index at: https://developer.rocket.chat/llms.txt > Use this file to discover all available pages before exploring further. # Contribute to Apps-Engine Being open source, we always welcome contributors to help us develop the ultimate chat platform. Contribute to our open source Apps-Engine framework, increasing the world of possibilities of integrations around the Rocket.Chat ecosystem. You can check out our Apps-Engine repository here. [GitHub - RocketChat/Rocket.Chat.Apps-engine: The Rocket.Chat Apps engine and definitions.](https://github.com/RocketChat/Rocket.Chat.Apps-engine) An excellent place to start looking at is our open issues and determining if you can help us with them. > When developing new functionalities, you need to integrate the local version of the Apps-Engine with your local version of Rocket.Chat. ## Get the Apps-Engine code 1. To start, clone the Apps-Engine repository and navigate into the directory by running the following commands: ```bash git clone https://github.com/RocketChat/Rocket.Chat.Apps-engine.git cd Rocket.Chat.Apps-engine ``` 2. Next, install all the required packages and compile the changes since that is what Rocket.Chat itself will execute. ```bash npm install npm run compile ``` 3. Setup your Rocket.Chat environment following the guide on [server environment setup](/v1/docs/server-environment-setup). 4. After setting up, go to the directory and run the following command: ```bash meteor npm install PATH_TO_APPS_ENGINE ``` Here `PATH_TO_APPS_ENGINE` is the path to the Apps-Engine repo you cloned earlier. 5. You can now start your Rocket.Chat with the `meteor` command, it will use your local Apps-Engine instead of the one on NPM. > [!NOTE] > Whenever you make changes to the engine, run `npm run compile` again - meteor will take care of restarting the server due to the changes. ## Troubleshooting Apps-Engine development - Sometimes, when you update the Apps-Engine code and compile it while Rocket.Chat is running; you run into errors similar to these: ```bash Unable to resolve some modules:  "@rocket.chat/apps-engine/definition/AppStatus" in /Users/dev/rocket.chat/Rocket.Chat/app/apps/client/admin/helpers.js (web.browser) If you notice problems related to these missing modules, consider running:  meteor npm install --save @rocket.chat/apps-engine ``` Restart the meteor process, and it should be fixed. - Sometimes using `meteor npm install PATH_TO_APPS_ENGINE` causes the following error: ```bash npm ERR! code ENOENT npm ERR! syscall rename npm ERR! path PATH_TO_ROCKETCHAT/node_modules/.staging/@rocket.chat/apps-engine-c7135600/node_modules/@babel/code-frame npm ERR! dest PATH_TO_ROCKETCHAT/node_modules/.staging/@babel/code-frame-f3697825 npm ERR! errno -2 npm ERR! enoent ENOENT: no such file or directory, rename 'PATH_TO_ROCKETCHAT/node_modules/.staging/@rocket.chat/apps-engine-c7135600/node_modules/@babel/code-frame' -> 'PATH_TO_ROCKETCHAT/node_modules/.staging/@babel/code-frame-f3697825' npm ERR! enoent This is related to npm not being able to find a file. npm ERR! enoent ``` Here `PATH_TO_ROCKETCHAT` is the path to the main Rocket.Chat server repo in your system. To fix this, we reinstall the package once again and delete the previous package. ```bash ~/Rocket.Chat$ rm -rf node_modules/@rocket.chat/apps-engine ~/Rocket.Chat$ cd PATH_TO_APP_ENGINE ~/Rocket.Chat.Apps-engine$ npm install ~/Rocket.Chat.Apps-engine$ cd PATH_TO_ROCKETCHAT ~/Rocket.Chat$ meteor npm install ../Rocket.Chat.Apps-engine ```
