Slack Compatibility
This is still a draft and doesn't cover all subjects about Slack Compatibility yet
Would you like to have your app listed in Rocket.Chat's Marketplace but don't want to rewrite all the backend for your Slack listing?
Look no further!
This "compatibility layer" will help you make your Rocket.Chat App talk to your backend in no time :)
Initialize your Rocket.Chat App with bindings that make it compatible with your Slack App implementation.
First of all, you're gonna need to scaffold out a Rocket.Chat App directory, so make sure you follow our Getting Started guide (it's really quick).
We're gonna build upon the example in our Getting Started guide with the LiftOff app. After you've created the new app with our CLI, you should have the following folder structure:
liftoff/
| .vscode/
| node_modules/
| .editorconfig
| .gitignore
| LiftoffApp.ts
| app.json
| package-lock.json
| package.json
| tsconfig.json
| tslint.json
Now, in your app's directory, you can install the Slack Compatibility Layer:
$ npm install RocketChat/slack-compatibility-for-apps
This will install the package directly from our repository on GitHub. We will publish it to NPM when it gets a bit more feature complete and battle tested.
That's almost it! Rocket.Chat Apps cannot include npm packages yet, so this package will copy itself to a
vendor
folder in your app so that you can use it. Your folder structure should be like this now:liftoff/
| .vscode/
| node_modules/
| vendor/
| | slack-compatible-layer/
| | | src/
| | | vendor/
| | | SlackCompatibleApp.ts
| .editorconfig
| .gitignore
| LiftoffApp.ts
| app.json
| package-lock.json
| package.json
| tsconfig.json
| tslint.json
Now you just have to extend the
SlackCompatibleApp
class instead of the default App
class from the Apps-Engine - this will make your Rocket.Chat App understand "Slack language". The only thing left to do is config the main class of your app with the features you have:import {
IAppAccessors,
ILogger,
} from '@rocket.chat/apps-engine/definition/accessors';
// import { App } from '@rocket.chat/apps-engine/definition/App';
import { IAppInfo } from '@rocket.chat/apps-engine/definition/metadata';
import { SlackCompatibleApp as App } from './vendor/slack-compatible-layer/SlackCompatibleApp';
export class LiftOffApp extends App {
public config = {
interactiveEndpoint: 'https://my.example.app/interaction',
slashCommands: [
command: 'liftoff',
requestURL: 'https://my.example.app/liftoff.command',
shortDescription: 'Tells the user if it is time to liftoff'
constructor(info: IAppInfo, logger: ILogger, accessors: IAppAccessors) {
super(info, logger, accessors);
That's it!
The below mentioned properties do not translate from Slack's Block Kit to Rocket.Chat's UIKit
- verbatim (string)
- url (string)
- description (PlainTextElement)
- confirm (confirm)
- option_groups
- max_selected_items
- confirm
- option_groups
- confirm
- confirm
- min_length
- max_length
- hind (added)
- fields
Last modified 4mo ago
