App Permission System
Prev Next
Each feature available in the Apps-Engine is mapped to a permission. Adding the permission in the app's manifest ( app.json file) will unlock the dependent feature to be used by the app. For example, if you add the send messages permission to your app's manifest, your app can send messages in the Rocket.Chat server. If your app tries to send a message without having the send messages permission listed in the manifest, Apps-Engine will block the feature, and the app will not be able to perform the desired action.
When installing an app from the Marketplace or manually using a ZIP file, you’ll be prompted to review the permissions that the app will access on your workspace. You can either accept the permissions to install the app or deny them to cancel the installation.
List of permissions
Here is a list of the permissions that you can add to your app:
Permission
user.read
Access user information
user.write
Modify user information
upload.read
Access files uploaded to the server
upload.write
Upload files to the server
server-setting.read
Access settings in the server
server-setting.write
Modify settings in the server
room.read
Access room information
room.write
Create and modify rooms
role.read
Access user roles
role.write
Modify user roles
message.read
Access messages
message.write
Send and modify messages
moderation.read
Access to read moderation dashboard information
moderation.write
Modify moderation dashboard information
threads.read
Access threads. Effectively allows the app to read all messages in a thread
livechat-status.read
Access Livechat status information
livechat-custom-fields.write
Modify Livechat custom field configuration
livechat-visitor.read
Access Livechat visitor information
livechat-visitor.write
Modify Livechat visitor information
livechat-message.read
Access Livechat message information
livechat-message.write
Modify Livechat message information
livechat-message.multiple
Access to read multiple messages at once
livechat-room.read
Access Livechat room information
livechat-room.write
Modify Livechat room information
livechat-department.read
Access Livechat department information
livechat-department.write
Modify Livechat department information
livechat-department.multiple
Access to read multiple departments at once
env.read
Access minimal information about the server environment
cloud.workspace-token
Access to request the workspace access token to interact with Rocket.Chat's Cloud Systems
ui.interact
Interact with the UI (UIKit)
ui.registerButtons
Use UIKit buttons
scheduler
Register and maintain scheduled jobs
networking
persistence
Store internal data in the database
slashcommand
Register new slash commands
video-conference.read
Access to read video conference information
video-conference.write
Modify video conference information
video-conference-provider
Act as a video conference provider in Rocket.Chat
api
Register new HTTP endpoints
oauth-app.read
Access OAuth information
oauth-app.write
Modify OAuth information
To add a permissions to your app, refer to the Add permission to your app section.
Default permissions
Out of the permissions listed above, the following permissions are present by default to ensure backward compatibility for apps that were developed before the permission system was introduced.
    user.read,
    user.write,
    upload.read,
    upload.write,
    ui.interaction,
    setting.read,
    setting.write,
    room.read,
    room.write,
    message.read,
    message.write,
    livechat-department.read,
    livechat-department.write,
    livechat-room.read,
    livechat-room.write,
    livechat-message.read,
    livechat-message.write,
    livechat-visitor.read,
    livechat-visitor.write,
    livechat-status.read,
    livechat-custom-fields.write,
    scheduler.default,
    networking.default,
    persistence.default,
    env.read,
    command.default,
    videoConference.provider,
    videoConference.read,
    videoConference.write,
    apis.default
Add permissions to your app
To add permissions to your app, add the field permissions to your app's manifest file ( app.json). It receives a list containing all the permissions that you are asking for. For example:
"permissions": [
        "name": "user.read"
        "name": "user.write"
        "name": "upload.read"
Adding permissions to your app.json overrides the default permissions, so you must include all required permissions for your app to function. For an example of how these permissions are used in apps, refer to the Action Buttons topic.
Once an app is on the Rocket.Chat workspace, it goes through several lifecycle phases unique to Rocket.Chat. The phases depend on the capabilities that your app has. To learn about the app lifecycle, head over to the next page.
